S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Yet Another Duo Valve Post
Old Dec 14, 2021 | 05:19 PM
bolenator2018's Avatar
2009 Mercedes E350 Sport, 1995 Mercedes S420 LWB, 2002 Mercedes SL 500 W AMG Package
Hi All,
It's officially the beginning of SoCal's 6 weeks of less than ideal weather. I'm now going on my second season of no heat in my 95 S420. I was trying to figure the problem out last year, but then it warmed up again and I forgot all about it.
Items Replaced:
1. Duo Valve (used but apparently tested for operation)
2. Interior Temperature Sensor in the overhead console
3. Coolant Flush
4. Firewall Hoses that lead to the heater core (unrelated?)
I went through the procedure of pulling the DTCs from the climate control cluster using the instructions on k6jsrf.com
DTCs:
1. 75 Heater supply unit circulation pump (A31m1), open or short circuit
2. 83 Heater supply unit left duovalve (A31y1), open or short circuit **)
3. 87 Heater supply unit right duovalve (A31y2), open or short circuit **)
After clearing the DTC's and driving with the heat set to high for about 10 minutes, only code 75 returned.
Problem I Caused:
The 3 pin connector going to the base of the module next to the solenoids crumbled when I removed it while replacing the duo valve last year. I then forgot to look at which order the wiring goes in, so I may have it hooked up wrong. I have tried to move the order around, but no dice. If someone could take a photo of their connector order that would be great. Also, if you have any ideas on where I can buy a new connector?
My first thought is that perhaps the replacement valve is bunk seeing as it's not brand new. Before I jump on procuring another one, I want to gauge your feedback on whether you think it may be something else.
Thanks in advance!
