S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 600SEL
Old Mar 19, 2022 | 01:02 PM
stuntflyr1's Avatar
1992 600 SEL & 1993 600SL
1992 600SEL
I probably already know but I recently had two new tires put on the front and since then the traction control activates (yellow triangle in the middle of the speedo) especially at higher speeds. The diameter is a noticeable difference larger than the rear tires. Is the traction control that sensitive to the difference in diameter between the front and rear wheels?
Old Mar 20, 2022 | 10:33 AM
chassis's Avatar
2017 GLE350 4MATIC
Yes
