S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Drifting
Old Oct 5, 2004 | 09:42 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Drifting
This may be suited better for the Teck talk area but a lot of you here seem to know this car quite well. ?? I drive a '96 S320 with 105k. It may just be me but the car seems to drift if I don't have both hands on the wheel. I'm talking flat, straight @ freeway speeds. I took it in and had an all wheel alignment done, wheels balanced and asked them to check front end parts for wear. everything was "good". But I still have a shimmy & the drifting.
Its not bad mind you just seems like I need to correct the stearing a lot Any Ideas ??
Thanks Rod
'84 190E
'96 S320
'03 GMC Duramax Pickup
Old Oct 5, 2004 | 09:50 AM
rsmcmahon's Avatar
CLK, ML320, 400E, 400SE
1. Wheels balanced correctly.
2. Correct tyre pressures.
3. Wheel alignment.
4. The steering damper. Only about $45 easy DIY
5. Shocks
Old Oct 5, 2004 | 09:59 AM
naadp's Avatar
I see Mesa so I'm going to throw this question out:
do you notice this on all roads at highway speed or certain ones? I've had an alignment check done on my cars twice, as it turns out nothing was wrong. Recently, a lot of the roads have been getting rubberized asphalt to reduce the noise pollution. It appears that because of the relatively soft surface, and the extreme heat, that cars are "sinking" into the pavement and leaving an impression.
It's sometimes hard to see this at highway speeds. Next time you're stuck in traffic on one of the roads that was surfaced a few years ago (like US 60), take a close look at the surface. You'll notice both a lot of ridges as well as "tracks" from traffic.
