S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Any problems ?
Old Oct 8, 2004 | 04:19 PM
LucaS420's Avatar
2000 Chevy Camaro z28 & 1995 Mercedes-Benz S420
Any problems ?
I was wondering if there are any common problems for 95` S420. Is there something I should know about ? or check out ?
Thank You
Old Oct 9, 2004 | 05:56 AM
guydewdney's Avatar
engine harness breaking down (insulation)
wire to air con compressor too short and snaps
air con leaking
vacuum door pipes leaking - esp boot / trunk
rerar window regulators failing (grease as a precaution)
general wear and tear on suyspension joints due to massive weight.
MAF / MAS sensor dying (dont use K&N filter)
throttle actuator dying
hth
guy
Old Oct 9, 2004 | 05:37 PM
LucaS420's Avatar
Thank You for a nice info. Doesnt seem like very serious things. I will check all of it.
Thanks a gain !
Lucas
