S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Burn Smell from the engine
Old Nov 13, 2004 | 06:22 AM
///S320's Avatar
S320W
Hi Guys,
When i drive my S320 around for like 20 minutes and this happens if i usually drive fast, i get a burn smell frm the engine compartment. It like some kind of wire or copper is burning. Would you know what that might be?
Thanks!
Old Nov 13, 2004 | 09:08 AM
Bernanke's Avatar
ouch no good, does it smell like rotten eggs or no?
Old Nov 13, 2004 | 10:15 AM
///S320's Avatar
S320W
Not really. It smells like some kind of wire burning. Would you know what it could be?
Old Nov 13, 2004 | 01:11 PM
rdanz's Avatar
Wiring harness? Any other problems like thing not working?
Old Dec 11, 2004 | 04:39 AM
MB AMG's Avatar
2002 E55 AMG
What is the deal with the rotten eggs smeall BTW? Aunt's 600SEL smeels like that when it's driven. Peeeewww!
Old Dec 11, 2004 | 11:50 AM
s0vietbenz's Avatar
1995 w140 s500
change your oil, don't use cheap gas.
Old Dec 28, 2004 | 03:35 PM
///S320's Avatar
S320W
Oil is changed with Mobil1 Full Synthetic Oil every 3000 miles. Gas is always 93 grade.
Old Dec 28, 2004 | 06:57 PM
Bernanke's Avatar
your catalytic converter is going bad, that smell is sulfur dioxide (which smells like rotten eggs).
Old Dec 28, 2004 | 06:58 PM
Bernanke's Avatar
check under car to make sure no insulation has gotten loose and is touching the exhaust system. alot of times on older cars the heat insulation under the car gets loose and touches exhaust system somewhere and can start to melt/burn.
Old Jan 3, 2005 | 12:50 PM
///S320's Avatar
S320W
Makes sense. Will check. Thanks Omey.
