S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Fuel Pressure Regulator vacuum line p/n?
Old Mar 3, 2024 | 11:03 PM
Zoso7's Avatar
06' SL65, 96' S500 & 09' S550
After replacing my fuel pump and filter on my 96' S500, I started getting some surging when cold and tripped fuel trim codes. While looking for any vacuum leaks I decided to replace my fuel pressure regulator as it was original. I noticed a small leak in the vacuum line going from the fuel pressure regulator to the intake. I did a temp repair on the line and the car runs great now. Does anyone know the p/n for this vacuum line? It's actually two lines with maybe a filter/restrictor or check valve in the middle? Before I cut lines and fabricate I wanted to see if this line has a p/n. I can't find any reference to it anywhere.
