S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
How to remove rear door locks on facelift w140??
Old Mar 22, 2024 | 03:59 PM
tsharples's Avatar
My '97 S500 had the dreaded can't open rear doors problem, and I ended up drilling access holes under the exterior chrome strips below the windows, and using a borescope to find the appropriate place to open the doors with a coat-hanger as described elsewhere. I've also pulled the interior door panels, and now want to pull out lock mechanism for a thorough removal of corrosion and re-lubing.
My question: how the heck do you get that lock mechanism out? The nearby access hole doesn't look nearly big enough for the required clearance, and I haven't been able to find any online instructions. Anybody here know how to do this?
Access hoes around lock mechanism
Thanks in advance,
Tom S.
