S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 600SEL will not start.
Old Apr 6, 2024 | 06:39 PM
stuntflyr1's Avatar
1992 600 SEL & 1993 600SL
1992 600SEL. I hit such a large pothole that it sent the car into ASR "limp mode". I pulled the car over and pulled the battery cable for a few minutes hoping that would "reset" the system. It did not. I was able to "limp" the car home but it will not start. No power to the fuel pump relays and I'm assuming no power to the ignition systems. I jumped both fuel pump relays to power the pumps but still no ignition. Signal for both come from N3/4 ECU. I've heard comments from past years ago that there might be an "impact" reset switch? Please help here!
Old Apr 8, 2024 | 09:03 AM
bborden51's Avatar
1993 600 SECw140
With a rubber mallet, lightly tap down all of the modules in the computer box under the hood. Your accident may have loosened the connections. Hope that works. Good luck.
Old Apr 8, 2024 | 02:10 PM
stuntflyr1's Avatar
Mmm....did the obvious already.
