S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Part sourcing info
Old Nov 3, 2024 | 01:11 AM
Takiz's Avatar
Part sourcing info
I have 1995 s500 that I got as a project car. the car is in decent shape but the weirdest thing is the car has a limit of approximately 4,500 rpm no matter what gear its in. It shifts smoothly but if i floor it, it bounces off that limiter and wont shift. After a little bit of research and having the engine codes from the pins. I suspect the issue is a faulty VSS on the right rear axle. Anyone know where I can find a replacement part for it so I can start enjoying this car. Any help would be appreciated, thank you.Pin 6
DTC 5: right rear axle VVS sensor
https://www.w124performance.com/docs...19_1992-95.pdf thats the link i used to figure out thats its the VSS sensor
