S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Trunk problem on '96
Old Nov 30, 2004 | 08:46 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
I can't get the trunk to open except with the key at the trunk. with out the key the button pushes in but it will not open. The switch on the dash worked untill recently but even then I had to switch it a few times before it opened. now nothing. Did I set some lock unknowingly or is it just broke. I couldn't find a bad fuse but unsure what fuse it is. Any davice ??? This is in a '96 S320
Thanks Rod
Old Nov 30, 2004 | 09:11 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
trunk release
The trunk is released by the "infamous lock, lumbar, headrest, gas door, HVAC backup , pump under the rear passenger seat. If all of those things work there is a electrical vacuum valve in line to the tunk release. I would think either the switch, the diaphram at the lock or, the control valve seem to be defective. There could be a chance there is a leaking hose. Toubleshooting the vac system requires a "handi-vac" it allows you to draw a vacuum and see by a guage if it holds, typically $50
Old Nov 30, 2004 | 11:07 PM
brett san diego's Avatar
1997 S600 Sedan
Since it seems all your other locks work, your pump is probably fine.
I would first suspect an air leak in the line going to the trunk release (could be a bad actuator at the latch or just a separated connection). Or the latch release could be mechanically stuck. You'll just have to dig in there and take a look to see what's up. Remove the trunk liners around the latch and on the right hand side. The line runs down this side of the car. With the trunk open, use your thumb to close the latch, then push the button and observe. You should hear the hiss of any air leaks. You can disconnect a line to see if you're getting air from the pump at all.
Good luck,
Brett
