S320 HARD & DELAY STARTING
Some people think its some sensor -- some say its Air Mask -- please help me i have already paid enough for the car.
Brett
I will check to see if any of the air intake pipes are loose or broken. I'm also tring to see if the dealer can just have it checked out tomorrow.
Will update you as to what they think the problem is.
The problem is solved ! I took it in to the Dealer since alot of mechanics outside diagnosed different types of probelms that was causing it. The dealer said its my fuel pressure regulator that causing this problem. The replaced it and adjusted the throttle and decarbonized the plugs and all seems to work well. Its starts perfect and have not noticed any missing as well.
