S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Phone system?
Old Dec 13, 2004 | 01:57 PM
dee7's Avatar
1992 500 SEL
Phone system?
Does anyone know what the original phone system is for a 1992 Mercedes-Benz 500 SEL? I have the michrophone by the visor, but curious to know where the phone system is and probably do some configuration.
Thanks for any help
Old Dec 14, 2004 | 09:54 PM
brett san diego's Avatar
1997 S600 Sedan
Check the trunk, left side behind the trunk liner. That's where it is for
my car. 97 S600 sedan.
Brett
Old Dec 15, 2004 | 01:10 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Phone
I have the Phone out of my '96 S320. It pluged in on the pasanger side of the trany hump. Its yours for the cost of shipping if it will work or is what you want. If I get your email I can send a picture. I ts in great shape no signs of ware. Took it out when I bought the car last year.
Old Dec 15, 2004 | 02:16 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
92 Phone
The 92 was an "analog OKI system" the transmitter/rcvr sat in the trunk wall behind and below the antenna. It had a splitter hooked to the antenna so that the phone used the AM/FM antenna for cellular. Some cars had the splitter installed in others it was installed as part of the "cell" option and in some cars the antenna was not a "Tri-Band (black top). The car was factory wired and had the control head in the glove bin above the center vents which would allow hands free dialing, memory , and other display options. There was a cradle in the console for for handset use but had no dialing functions. I dont think you have a microphone since the mirophone was in the "glove bin" portion of the control head, a factory service option provided a separate microphone in the bolster below the igniton switch. The bin had a hole cut in the rear to accept two cables fror the control head, which are back there. The grill you speak of, is the aspirator vent that samples the cabin air, and routes it back to the heater. The phone provided a mute function to the radio, with a display of PHONE, and there were two speakers installed on the outboard sides of the dash for phone audio, with no radio function. The power antenna also recd a input from the phone/handset to raise it whenever the switch on the side of the handset was on.
I have also removed it and the space is useful in both the bin and console.
I would suggest you invest in a hands free kit, thee are some no mar mounting kits available, since adapting to the existing cables can be done if you are a qualified elecrtonic technician with a lot of patience since the connectors are proprietary, and have changed in 94 and 96 with the changeover to hand held units which also are proprietory units to MB manufactured by Motorola.
