S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Timing Chain Question
Old Jan 14, 2005 | 12:05 AM
BenzKid24's Avatar
a Few Nice cars.
Hey guys got a Q for ya since my s500 is a 94 i heard rumor that i dont need to change out my timing chain @ 100k like other older benzes??? there to be changed around 300k..my car is at 97k now and owned since 76k..and 2nd the evap thing everone is talking about,the part is only $189 bucks..so why does everyone say there a $3k job? my family owns a small used car dealership,where i am the manager.so its shouldnt cost that much for me anyhow??? anyone any of these q's?
Old Jan 14, 2005 | 01:44 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
I have asked my dealer about timing chain, and he did not suggest changing it 85 K on my92 SEL, "dont worry about it yet" . As to the AC evaporator, think about, the dash and part of the console come out completely, and I think they also have to go in the heater plenum under the dash. While in these areas it makes sense to change things that are maginal. They changed hoses, replaced the dryer, and a few other things. I would never let anyone who has not done a few of these do it. I have seen a few of these in the local MB dealer shop (apart) and it it is a jumble of wires, hoses, etc.
Old Jan 14, 2005 | 10:21 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
On the timing chain issue, typically they are replaced when the tensioner can no longer take up the slack. Replacing one at 100k miles is a safe bet, especially when you consider that a new head or block will run in the thousands. I have always replaced my own timing chains, it is fairly straightforward if you have some mechanical ability and the right tools. The best part about replacing the timing chain when it is needed, is that it makes the car run so much better, after all it is responsible for keeping the valvetrain in time with the lower end!
-D
Old Jan 14, 2005 | 10:49 PM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
First the evap requires the entire dash to come out. The book says 22-24 hours of labor alone. At $100 an hour most dealers or good shops charge, you are at $2200-$2400 before any parts. You want a shop that has done a few W140 evaps, before they do yours. It is a big complex job don't let someone learn on your car. Although I think if you shop around you might get it done in the $2200-$2500 range.
As far as the timing chain issue ask a few people that know the M119 V8, but from the techs I have talked to they pretty much say don't worry about it.
Old Jan 15, 2005 | 03:06 AM
BenzKid24's Avatar
a Few Nice cars.
thanks guys for the info,so far my evap hasnt had any probs,however i did buy it at 76k so it might have had the job done..it currently has 97k now..i just replaced my Blower regulator myself,pretty ez fix..later guys...
benzkid
