94 S500 SRS indicator light on
S500
Indicator light will go out about 5 minutes after the car has started. I read somewhere in a previous post that it could be a sensor but didn't give a fix for the problem. Is this something that will require a pro to fix?
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
I brought my 95 s 500 to local indy repair shop to check SRS light. It comes on as car started and goes off about 4 minute later. They said diagnostic computer read is seat belt. There is a ETR sensor in the base box of seat belt that connected to SRS system . They just reset the code and light is turned off. If it turned on again they said the seat belt should be replaced. It was ok to drive back home.
johny,, ksbenz
johny,, ksbenz
