S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
The Diffrence between 300 and 320
Old Feb 25, 2005 | 02:01 PM
darky_minded's Avatar
cl600
guys i wanted to ask about the the diffrence between 300 and 320 engine ok i know the first has a delco and the outher dosent the fule injection system and a few outher stuff but what about the power would love it if some one can add pics to
i have a 560sec and a s500 coupe and thinking of buying a 1992 300sel so just wanted to know a few things about the car befor buying it
Old Feb 25, 2005 | 03:48 PM
leloz's Avatar
2018 GLS63 AMG
If my memory serves me correctly, the 300SE and 300 SEL W140 both had the same 3.2 liter 24 valve as the S320 SWB/LWB. The 1992-1994 model years had the older grill, taillights, yellow fogs. 1995 still had the "turn" style climate control and the reverse antennas. In 1996 I believe the climate control unit was upgraded and the Bose stereo became an option. 1995-1996 had a different grill, headlights, tails. The W140 then went another minor transformation in 1997 with the monotone paint schemes, different tailights, and wheels. I am probably missing some information, but I hope this helps some.
Old Feb 25, 2005 | 05:55 PM
Bernanke's Avatar
they are essentiallly idential cars, motor wise the intake wraps around to the opposite side on the S320, where as the 300 has the intake on the drives side away from the headers on the right side (better design in my opinion and easier to make intake for). another difference is the 300SE is quit a bit quicker because it has the 3.69 gears which was the most aggressive gearing mercedes ever used in any of their cars, by comparison the V8's only run 2.54 so you can see its a big jump, this made the performance with the 400SE identical but they were too close so mercedes pulled back its gearing for the S320 and eventually added an overdrive 5speed.
Old Feb 26, 2005 | 04:21 AM
cl600
well i know the diffrence after the face lift when the changed the grill the head lamps the tali lights even the seats but all that is easy to do i mean i found a total lost s320 with seats that looks like the coupes i cant remmember its name i was thinking to change the interior of the car couse the crashed one is the indivsual leather dash i mean looks like the s600 from the insied so it would be nice the most important thing to me is the engine altho i do get a 30% discount on parts i dont want a car that is a pain in the neack and when i drove the s280 man there was no power in that car
and yeah i wanted to ask dose the 300sel has electronic fule enjection or is it like the old ones semi-fule injection like my 560sec
Old Feb 26, 2005 | 06:41 PM
Bernanke's Avatar
300SE/S320 is definately the most reliable of the W140's b/c 6cyl is pretty much bulletproof and never ever has problems. i have yet to have a single motor related problem. anyways hope that helps
Old Feb 27, 2005 | 05:21 AM
Ifly55's Avatar
Well the inline 6s are bulletproof but they have a history of oil leak coming from the top gasket seal. I'm going to admit that the inline 6 is a pretty solid unit if the damn thing can pull all that weight in a W140 . The 8 cylinder is a more potent unit, but still I have respect for the inline 6 . Some people fill that the 6 is underpowered but in its own respect the engine holds its own pretty well.
Old Feb 27, 2005 | 03:54 PM
Bernanke's Avatar
ya poor engine has to push nearly 5000lbs lol. The good news is the motor is actually under rated when i dynoed the car it dynoed more than my M3 stock which was rated at 240HP. like most mercedes motors and specs its underrated which is good to know.
Old Mar 1, 2005 | 03:16 PM
cl600
well i found a w220 s230 2000 model but to be honist alot of the guys i know who have this car are heaving big time problems with it i even went to one of my firends who works at an mb workshop and said its a headach so and secondly itrs not fully loaded not lether seats no rear blinds no bi-xion headlamps so it would really be need dome work to make it nice so said to my self ill go for the 300 sel for every day use and keep the outher cars for the week end
Old Mar 1, 2005 | 03:42 PM
Bernanke's Avatar
we are talking about a W140 b/c thats this forum so i cannot comment on S220, but W140's are solid
