Airmatic repairs SUCK!!!
Well, my Airmatic warning comes up after driving for about an hour, but once I restart the car, it reads "No Malfunction" and everything is ok. The car still levels out when it is off, so I am not sure what is wrong, it could possibly be just the relay, but I might be trading the car in for a more recent model or an E55. I have 112K miles and have an 2000. This started happening after the car was in service and they had it on a lift.
2004 CL500
#32
Well thanks for the info. I was able to go to a dealer and purchase the relay for about $57.00. I was able to get there without any malfunction warnings coming up. I replaced it and drove even further to get home with several detours and still no warning light. I hope this was the reason I was getting the malfuntion codes, because it is a cheaper fix than replacing the air compressor($410.00 for the part itself), which the dealer had mentioned is usually the problem. The true test will be the trip to the office in the morning, which will really let me know if everything is ok or not.
#33
1 Post
2000 S430, 1999 E 320, 2 K5 blazers,
Re
hey fellas, i have a 2000 S430, my front shocks were going out. I tried to get the shocks replaced at the dealer, they said they were on back order and could be like a year before i could get one. My service guy said Mercedes came out with a repair kit for the bags and instead of costing me 4K i only spent 500 installed. so far so good but i want to do the washer lowering just afraid its going to mess up my shocks.
#34
Originally Posted by D2-AUTOSPORT
With such a high rate of failure, I wonder if it would be worthwhile to organize a unified front and propose that MB warrant airmatic repairs (sort of like the 6yr/100k warranty BMW instituted on all 02/03 745's)
It is unacceptable that on such a premium vehicle, owners have to "eat" the cost of these repairs.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#35
1 Post
W220 M113K
02 s430 airmatic
I have an 02 s430 and it has the airmatic warning light on, but when you turn the car on it goes up no problem and when you press the button for the car to rise it gives no problem and goes right up and stays. (tested to see if weight on the hood would bring it down and nothing it stayed strong, brought it to a specialist and he test the seals by spraying water to see if the front was leaking but nothing, he qouted $200 for something that needed to be done. wondering after reading these forums its the relay also any ideas?
02 S430 67k all lights upgraded to 03 plus thanks to ebay all OEM new, 20% tint all around
#36
Cost To Repair Airmatic In Toronto
My Airmatic went out yesterday. 2001 S430 with 79,000km. I have only had 2 months.
Took it to the Mercedes Service Center, rude service by the way. Wanted $1000 for the compressor and $700-800 for labour. This is in Toronto.
What pissed me off was that they would not call my aftermarket warranty company to authorize the repair. So I called the company, they said that they would pay for the fix. The warranty company and I could not understand why mercedes wouldn't call.
The mercedes rep says it is company policy that they not honour non-mercedes warranties.
Mercedes wanted me to pay for the repair and submit the bill to the warranty company.
Has anyone ever had this problem with non-starmark warranted cars?
ps. I will be moving back to the japanese cars after my warranty runs out. My '92 Toyota keeps on going even after all the abuse I have thrown at her.
#37
1 Post
W220 M113K
Weird mine did and they keep calling for each part they werent sure about
#38
2001 Mercedes Benz S55 AMG
https://mbworld.org/forums/s-class-w220/169414-my-03-s55-rearended-55mph.html
I have nothing against Japanese cars because I also own a Lexus but the advantage and protections of a solid German car in the event of an accident outweighs the lower cost and maintenance bills of a Japanese car...
Good luck!
#40
2015 E250D
Mercedes has already come up with a repair kit for the airmatic strut leak problem. This repair kit is 50 dollars plus installation per side. This beats 800 dollars per shock many have paid before. IF your shock is leaky, your compressor (pump) will run longer and cause it to fail as well. If you have a hairline crack on the top of the strut, I would highly recommend getting the repair kit installed before having any other problems. I have done several myself and it does not take longer than 30 minutes per side to do.
#41
2000 S500, 2001 Camry,1996 Honda SUV
"I have done several myself and it does not take longer than 30 minutes per side to do."
We all want to read how to do it step by step guidance.
Thanks.
Thanks.
#42
S500/W220/2000
#43
I can totally relate my Friend...Been there and done that...Just think of it as a very high maintenance Girlfriend because sometimes you can love them to death and sometimes you want them dead
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#44
2015 E250D
I don't mind writing up a brief summary of what is required but you will require 2 special tools. One is to thread the new check valve on top of the strut in without scratching it. The second tool is the tripod head. both tools run 250 dollars. A heat gun will be required as well to remove the old filler on top of the strut. If anyone is interested in doing this, let me know. I'll take a picture of a repaired strut as well. The repair kit has a new metal round plate with a rubber o-ring aroung it. The current metal top plate in the w220 does NOT have a rubber o-ring. The sealant on top of the strut is what holds the air in. As soon as it cracks (most common), the air begins to seep out.
#46
2015 E250D
no telling what the life of the new kit is since it has only been a couple of months since it came out. At an engineering stand point, it has been designed to rectify the problem that plagues all air matic struts. So, in combination with the rubber o-ring around the top metal plate and some good quality sealant over that, I am sure you can expect many many years of life from the struts.
And yes, I would recommend it as a preventive measure if your strut has a crack on top weather it leaks or not.
#47
Sunman,
If you don't mind, I would like to request to post this repair procedure for the preventive maintenance for us. I would appreciate part numbers for repair kits and tools too.
Thanks again.
Thanks again.
