Vibration at 60 mph
Originally Posted by thericker55
To help you out my fix was changing to Michelin Pilots, in this case the more you spend the better (Michelin being the premium $ brand)
2005 S500 4-Matic, 1978 450SL
Originally Posted by gsleung
Now, I have any problem with the car - the damned cup holder wouldn't close... But that would a separate post...
Obviously, a problem caused by the new Michelin Pilots!
Hi guys, I have w220 and its been vibrating every time i start up the engine. whenever i rev up the engine it would vibrate through the seats however i notice that once the engine temperature reach 90c +. whenever i drive on the highway the engine cools to about 80C and it would start to vibrate but when i stop and let the temperature rise it would be smooth again... I was wondering if anyone else has experrience this or have any clue whats wrong with my car thanks!
Ive changed my trans mount and motor mounts recenetly
'96 SL600, '05 S55 AMG, '06 C230
Cheers,
Jeff
Vibration
So far I have checked the rotors for true, replaced the propshaft ( with second hand younger vehicle c/w second hand donuts and centre bearing ), replaced the diff and drive shafts, fitted new engine mounts, the wheels and tyres have been replaced and balanced, its had a four wheel alignment.
This has been going on now for 4 years over 25k miles and it is getting worse, started small so only I could notice it as the driver, now everybody can hear it. There is a noticeable change in the "volume" of the rumble on different road surfaces. I don't use the car much for work, for holidays really and an unreliable car is not what you want 1000s miles away from home. The steering wheel and seat are transferring the vibration t omy body but not overly at my feet.
The only thing I haven't done is address the transmission or play with the torque converter.
Have you remedied yours yet?
