Help, Newbie
Old Dec 7, 2005 | 11:45 PM
acts238's Avatar
2000 s430, 1992 Legend Coupe
Help, Newbie
What's Up! I'm new to the forum. My name is Russell. I have a 2000 s430. I have used the search option but need some more advice. I recently rotated my tires and the drivers side is sitting lower than the pass. side. The airmatic is raising and lowering the car. I hear the compressor cutting on and off. The level of the car was fine before I rotated the tires. I checked for air leaks on the top of the struts. No leaks there. (But I do see some small cracks on the black housing) Also there is a buzzing sound almost like a whine coming from the engine bay. Not sure where it is coming from. Anybody out there can help?
Old Dec 7, 2005 | 11:50 PM
IluvS500's Avatar
Jeep Grand Cherokee Overland
well the cracks are certainly no good...the whining i cant help with but i would go get those cracks checked because you may have a slow leak or something.
Old Dec 8, 2005 | 12:01 AM
acts238's Avatar
Where can I buy the repair kit and how much? Does anyone here rotate their own tires? Would a suspension calibration fix the problem with the drivers side. Or did I mess something up when I jacked up the car?
Old Dec 8, 2005 | 09:18 AM
acts238's Avatar
Question
I checked the cracks on top of the suspension again. I sprayed with windex and shook the car. It shows I do have a leak on the driver side when I shake the car. Since there is a leak, would that cause the compressor to constantly run? I believe the loud hissing,whinning noise is the compressor. The noise has gotten louder and more frequent, to where everytime the engine is running you can here the whine. How do I check to see is the rear shocks are leaking? Also there is a clicking noise coming from the drivers side of the engine bay.
Does anybody know what part this is
Old Dec 8, 2005 | 11:09 AM
Jayhawk's Avatar
S500/W220/2000
I'm no expert, but I would say get thee to thy dealer, as soon as possible. Have it checked, and repaired if necessary, before you do some real damage.
Old Dec 8, 2005 | 12:25 PM
acts238's Avatar
Just spoke with MB of Cary. The repair kit is only $124 per shock. Has anyone done this repair? I will also get a relay switch for the compressor.
Old Dec 8, 2005 | 12:45 PM
acts238's Avatar
Did I post this in the wrong forum? Maybe I need to post in the Tech forum or the DIY forum?
Old Dec 8, 2005 | 01:26 PM
Jayhawk's Avatar
S500/W220/2000
If your not getting much of a response from us sudan-owners, you might post it in the Tech Talk forum.
Old Dec 8, 2005 | 02:48 PM
acts238's Avatar
Thanks, I just posted over there. I went to the dealer and picked up my repair kit, I got it for 115 with tax. I priced a compressor and was surprised that it was only $240. I was shocked. The parts guy said MB lowered the price. I also get 15% off. If I can fix the cracks , I'll post a DIY.
Old Dec 8, 2005 | 02:54 PM
Jayhawk's Avatar
S500/W220/2000
Merry Christmas!
I wouldn't try to DYI on something like that, but guess it will be cheaper--unless, of course you break something even more expensive in making the repair.
Good luck!
Old Dec 17, 2005 | 12:45 AM
wcbaird's Avatar
2015 ML350, 2016 E400, 1986 SEC560
Airmatic
I've replaced a compressor and relay as the relay sticks and kills the compressor. It's wise to repair the leak as soon as possible so your compressor doesn't run more than it needs. As a note, I had a line pop apart (came out of the sleeve) which had to be repaired today FOC.
