options for sirius radio???
Old Dec 8, 2005 | 02:28 PM
mbsas's Avatar
i have a 2000 s500. i bought an aftermarket sirius unit and had it installed. however i have static from the radio. i talked to nav tv and they said this model comand 2.0 will not let me put a tv tuner unit in it with additional av outlets . my question is what can i do to get rid of the static bleeding in through the fm radio stations?
Old Dec 8, 2005 | 08:43 PM
Can Drive 55's Avatar
2005 E55
If you are using the modulator that converts the signal to an FM frequency so it will play on the existing system, then you might try other frequencies if you can make selections. I have on that I have used in the past, and it is impossible to find a vacant frequency in a large metro area. The cassette adapter doe work well if you have a casette. You would have to live with the wire, but it would sound OK.
