2001 S500 Transmission Fluid
Old Dec 19, 2005 | 02:09 PM
santalk's Avatar
How do you check the transmission fluid level on the newer "lifetime fill" transmissions? My 2001 S500 had a slight leak from the pan gasket and I would like to add some fluid if possible.
Old Dec 19, 2005 | 02:45 PM
D_TECH's Avatar
you'd have to buy the MB dipstick and a red lock for after youre done checking it.
Old Dec 20, 2005 | 02:54 PM
santalk's Avatar
Thanks for the response. How about adding fluid? Done through the same hole?
Old Dec 20, 2005 | 06:03 PM
D_TECH's Avatar
no problem and yes
Old Feb 1, 2006 | 06:05 AM
gsleung's Avatar
Would you be so kind to tell or show me where that hole is? thanks
Old Feb 12, 2006 | 11:18 AM
implausible's Avatar
Take off the air cleaner. On the passenger side, toward the firewall is a tube that extends up with a cap that should either have a black or red locktab.
