Trunk Release
Old Feb 5, 2006 | 04:56 PM
kenstudios's Avatar
Trunk Release
My trunk cannot open. Any other way to open the trunk besides the 3 normal ways - trunk latch, remote and the trunk release on the driver door?????????
Old Feb 5, 2006 | 05:15 PM
newton22's Avatar
BMW E39
You tried using the key to open the trunk right?
Old Feb 5, 2006 | 07:30 PM
kenstudios's Avatar
Believe me, I've tried everything I know how. The thing wont burge.
Old Feb 5, 2006 | 08:51 PM
ScottCLS55's Avatar
Lexus
If you take the back seat out and can get into the trunk there should be a safety release. Its just in case someone gets locked in the trunk..
I'm not sure if you can get into the trunk from the back seat, there may be metal in between.
Old Feb 6, 2006 | 10:50 AM
kenstudios's Avatar
Thanks guys. I've given up on it. I have hopefully my last appointment this Friday and once they get this open MB will be out of my life.
Old Feb 6, 2006 | 11:35 AM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Yeah, the gas tank.
Old Feb 6, 2006 | 11:38 AM
Vader55's Avatar
Have you slid the metal key out of your remote and tried it in the lock of the trunk ? That will open the trunk for sure.
Old Feb 6, 2006 | 12:13 PM
kenstudios's Avatar
Not in my case. 2 days of trying that key. I have a trunk load of groceries that need to come out. The milk, icecream and bread I already know their fate. This car spends every other weekend at the repair shop and I'm tired of it. Anyone has any C4?????
Old Feb 6, 2006 | 12:17 PM
Jayhawk's Avatar
S500/W220/2000
Get thee to thy dealer--ASAP!
Old Feb 9, 2006 | 09:48 PM
jonadavi's Avatar
S430 (wife drives E320)
If it has the hydraulic pump system (my 02 S430 just had this challenge) they have to manually crank it open at the dealership and replace the hydraulic pumps. Sometimes they over-torque and don't stop running.
Total cost for me: $1,230. OUCH!
Old Feb 11, 2006 | 10:42 AM
kenstudios's Avatar
Took it to the dealer Friday morning but it snowed so they closed without touching my wheels. I have to wait till Monday to know anything.
Old Feb 14, 2006 | 05:45 PM
kenstudios's Avatar
The electric release switch was jamed. Thats why the mechanical key would not unlock it. I dont know how he got it open but he did.
Old Feb 14, 2006 | 07:24 PM
Jayhawk's Avatar
S500/W220/2000
I've heard of this happening before. Would you please elaborate as to how, what, when, where, etc. so the rest of us can try to avoid this nasty situation.
Old Feb 15, 2006 | 10:12 AM
kenstudios's Avatar
Mine was related to the previous water incident I had. Due to a bad rear SAM which controls that release switch, the trunk would not release even with a mechanical key. When I slammed the trunk that was it. The rear SAM controls (among other things) the rear lights, reverse lights, rear turn signals, trunk lights, trunk vacuum assist and that release switch all of which I had a problem with. All fixed now. The only thing I would advise is make sure that reed valve on your air intake is super clean.
Old Feb 15, 2006 | 12:33 PM
Jayhawk's Avatar
S500/W220/2000
Wow! Thanks. I'm headed for garage now to check my "reed valve." Is it really a valve or is it just a weep-hole?
Old Feb 15, 2006 | 12:37 PM
kenstudios's Avatar
It's really just a hole but since it drains, they call it a valve. With your hood open, you'll have to pop open that plastic mesh over it to gain access inside.
Old Feb 17, 2006 | 08:44 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Jayhawk,
I had the reed valve problem on my 2000 S500 - a tube extends about 3-4" below the hole. Apparently during some work before I bought the car, someone had bent and pinched the drain tube up under the air intake well. Fortunately, all it did for me was keep any air from circulating in the A/C & heating system (the water level was about 2" below the top of the well, so it had not flowed into the passenger compartment.
Once I found the problem and drained the water, my A/C circulation slowly returned. Some electromechanical components had gotten wet, but they dried out and functioned OK. Kept watch, there was no rust.
Some folks who responded to Kenstudios' original post on the water problem have suggested drilling an additional hole in the intake well. If you tend to accumulate a lot of small leaves, seeds. etc., you might want to consider that.
Old Feb 17, 2006 | 12:19 PM
Jayhawk's Avatar
S500/W220/2000
Originally Posted by Skylaw
Jayhawk,
Thanks Skylaw. I have had no trouble w/ mine (yet), but plan to keep an eye on it from now on.
