OBD2 code
Old Apr 15, 2006 | 09:55 PM
lloyds's Avatar
2004 CL500
Question OBD2 code
Hi all,
Used a OBD2 scanner on my car today and got the fault code 0170 and 0173 which mean the "right and left cylinder mixture adaptation reaches limit value". Does anyone know what this is as I am at a total loss. I have put some injector cleaner in with my last fuel up and I am wondering if that has anything to do with it.
Old Apr 15, 2006 | 11:57 PM
ScottCLS55's Avatar
Lexus
Mass air flow sensor is going bad.. DO a search and you will see. I bet your above 75k miles arent you?
Old Apr 16, 2006 | 06:12 AM
lloyds's Avatar
2004 CL500
Yes up to 98000 now. Had problems with the MAF before but it was not replaced just checked as car started working fine. Guess I had better start saving up for one.
Old May 6, 2006 | 07:04 PM
cbsmopass's Avatar
2000 s500
I got this today also. Glad it's just the MAF, I've read enough posts to know it was a matter of time. If this is my fix I'll send another post. only 65k miles but the car does run good, although I don't like the way it shifts(bought it with 55k). Makes sense by reding other posts.
Scott
Old May 6, 2006 | 10:00 PM
RobertG's Avatar
things with and without wheels
Just dont try cleaning it unless you have the replacement Maf on hand, cleanung it might fix the problem or make it worse.
Old May 7, 2006 | 05:21 PM
newton22's Avatar
BMW E39
And don't go to the dealer for replacement. Try and find one on ebay or something. And then consult us or a quality MB shop to the replacement.
Old May 7, 2006 | 07:29 PM
lloyds's Avatar
2004 CL500
Replaced my MAF finally and fault code cleared. Got the MAF part number 113 094 00 48 from good old E-Bay for £80 ($148) with postage and had it changed within 15 min. Car feels totally different a lot more responsive to the throttle and it now accelerates as a V8 should. Its unbelevable how much difference a small piece of tubing with a smaller piece of wire running through it can make to this cars performance.
