Dealer Decal Removal
Hello. The dealer I bought my 2000 S430 from has an ugly decal on the front of the trunk hatch on the left side. Is there anyway I can remove without messing up the paint? It needs a paint job anyway. Anyone have an estimate of how much it would cost to repaint?
Thanks.
Thanks.
Metro Card : (
Thanks.
Thanks.
Is it one of the sticky foils? The best results with cleaning things like that, I have with Brake-Clean. It is not harming the paint and also does not discolor plastic parts. I use to get rid of the terribly sticky pice tags also.
Hair dryer side-to-side about4-6 inches from the decal for about 1-2 minutes.Then use your finger nail to peel a corner up to get it started.Grab the corner with a pair of tweezers and keep moving the hairdryer while you pull it off.95% of the glue should come off with the sticker.
Caution
@ 1phd1jd
I said Brake Cleaner, the stuff to wash off the grease of new brake rotors
I DID NOT SAY AND RECOMMEND BRAKE FLUID!!!!!!!!!!!!!!!!! This would be the end of the paint and then you need a paint job.
