How to change bettery in the remote??
2001 S430
Hi,
My S430 remote started to give me trouble. It does not work some time. I have to tap it. How do I change the bettery in it?
Thanks in advance.
Thanks in advance.
Aussie_E350_Wag (07-10-2022)
S320L (W220)
Take out the actual key from the fob. Inside you will see a bit of plastic. Push this and then slide the inside of the key outward. You will find two CR2025 batteries inside.
I would take pictures if I had a camera to hand.
Cheers
Cheers
2001 S430
Originally Posted by justbecause
I put mine in a vice, then hit it with a hammer, then glued it back together.
Thanks ZMASTER007.
