RENNtech Lowering Module! Special
Old Aug 15, 2006 | 07:48 PM
James@Creative's Avatar
Renntech Lowering Module.
RENNtech's new generation lowering module now available!
This all new lowering module does away the analog control of competitors and replaces it with a module that is controlled by four digital microprocessors. Digital control eliminates the temperature variations as well as any inconsistencies of the older generation modules. This module will fit any ABC or AirMatic Mercedes using a user selectable switch.
The digital design also allows for a module that can be adjusted to provide any height between stock to a ground slammed 50mm lower. This is achieved by individual wheel height adjustment. Using eight position rotary switches the user can adjust each front wheel and the rear axle height individually.
This revolutionary device is encased in a watertight molded ABS enclosure and utilizes an automotive grade waterproof electrical connector. All required hardware as well as a comprehensive installation manual are included in the ready to install kit.
Standard Price: $1,495
RENNtech Introductory Price: $1,195
Creative Autoworks Introductory Price: $1,070
-Installation of Standard Module $85
-Modified Module with extended knobs for easy Access: $1195
-Installation of modified box underneath dash: $150
-Custom Location Call for Price!
