Automatic locks died ..
Old Nov 17, 2006 | 08:32 PM
shaw01's Avatar
2005 S55
Along wtih trunk opener and auto door closers ..
Is this a fuse? Anyone know where to look or what to do to fix it? 2001 S500 .. sucks when you have to open manually all the time!
Old Nov 18, 2006 | 07:41 PM
knockoutking027's Avatar
2002 S55 AMG
I have the same issue with a 2002 s55 . . . just posted a thread and waiting for a reply. Vacuums do not work, cant get into the trunk, keyless entry doesnt work, and the center console button does not work either.
Old Nov 18, 2006 | 10:59 PM
shaw01's Avatar
2005 S55
tell you what, promise to let you know if I hear anything here .. hoping it's soemthing as simple as a fuse .. but the people on this site would probably know or have some experiene with it.
Old Nov 19, 2006 | 12:45 AM
Darknessph's Avatar
IF it is not the fuse, you need to replace the vacuum pump, which is part #220-800-0348. Hope this could help you.
Old Nov 19, 2006 | 12:51 AM
Darknessph's Avatar
More info:
Originally Posted by J 2 Tha V
i had to jump my car due to my battery going out. afterward- my power assist didn't work either. took it to the mechanic and he put it on diagostic and cleared the codes the car picked up and everything works fine now. take it in and have them put the machine on it.
https://mbworld.org/forums/showthrea...ghlight=vacuum
Old Nov 19, 2006 | 03:15 AM
shaw01's Avatar
2005 S55
Thanks ..
Thank you so much for the reply .. now I hate to sound like the newb. I am to takin care of my own car, but would you know where the fuse box is and which one controls the vacum pump?
Don't have an owners manual and will start searching other threads, but thought I'd ask here too.
Old Nov 19, 2006 | 04:56 AM
ksc's Avatar
ksc
S500
fuse box is in the engine compartment on driver's side.
there should be a fuse chart in the tool kit (underneath trunk floor).
Old Nov 19, 2006 | 11:12 AM
kenstudios's Avatar
You have 3 fuse boxes. Two in the engine compartment (left & right) and one under the rear bench seat passenger side. You will need to check the chart for proper fuse locations. Sometimes your rear SAM (signal activity module) could be bad. The rear SAM is the entire thing holding all the fuses and relays. That was my case.
This could also be possible. Check the batteries in your remote key. They might be dead or dying and nolonger support locking and unlocking but still allow you to start your car.
Old Nov 21, 2006 | 06:22 PM
shaw01's Avatar
2005 S55
Very happy to report it was just a fuse .. replaced and all is working great! Knockoutking if you are still waiting on a response I would recoment checking the fuse as a quick fix .. would like to say I did this "do it yourself" job on my own but was on the run & ended up paying $75 for a .89c job .. yeah, I know .. lazy ***!
Old Nov 29, 2006 | 05:47 PM
2002 S55 AMG
which fuse # was it? engine compartment right or left or rear passenger seat?
Old Nov 29, 2006 | 06:27 PM
shaw01's Avatar
2005 S55
New thread comin ..
one under rear passenger seat .. and it died again .. gonna start a new thread .. it's been bad, can't get it fixt til friday at least.
Old Nov 29, 2006 | 06:31 PM
2002 S55 AMG
how do i take that seat out? car has rear power seats . . .should i move it fully forward or fully back and from where do I yank on the thing? do you have the fuse number ? thanks
Old Nov 29, 2006 | 06:54 PM
shaw01's Avatar
2005 S55
don't do it ..
my experience told me not to bother trying .. unless there is someone with some real knowledge on how to access the rear fusebox (and there are plenty with more knowledge on this board) .. i found it inaccessable, covered with a steel plate bolted down with some backwards looking bolts ..
