please help with my 2001 s430..problem when driving
http://www.alldata.com/tsb/Mercedes-...8C/200081.html
If the noise persists, then the last culprit would be.. the thrust arm bushing.
If not... Other two ball joints that joins the steering knuckle, could be problem. (there are total of three ball joints on each side of the front axle.)
There has been a Mercedes Star TSB about this suspension noise.
I remember TSB saying that whole sub frame needs to be replaced if the point where control arm hooks up is worn, caused by the worn out control arm bushing.
I will post it here if I could find it later.
What's up with the transmission? did you replace the O-ring for the transmission electrical connector?? what's happening to it?
It sounds like you pulled out the electrical plug, and did the O-ring change.
Make sure that you plugged in the connector right, otherwise it could leak very easily.
Running on low transmission fluid could be very, very bad for the tranny.
anyways,
*sigh*
good luck with your car..
( at the same time, I am also starting to get worried about my car because I have similar symptoms )
thanks for careing, the tranny plug seal finally fix by mercedes and it's only cost me $145 with tax...i learn my lesson don't ever bring the car to any shop but only mercedes dealer, now the only problem the boders me is the noise, i'll try to get it done but the upper and lower control arm are so expensive...does mercedes only sell the bushing or i have to get the whole thing?
I would first try the ball joints before the control arms. At 50k + miles, the ball joints are the most vulnerable parts on our cars' chassis.
BTW, did the transmission leak get sorted out just by replacing the seal?
What does it say on the billing statement? Does it say "electrical Pilot bushing"?
Please let me know :-)
It.cost Me $145 At The Dealer PART AND LABOR TO GET IT FIX ...if You Have The Same Problem, Get It Done Asap...takes Them An Hour Job...
Also Where Can I Find Those Bushing?mercedes Part Dept. Told Me I Have To Get The Whole Assambly...upper$290 Lower $295..
I Went To A Shop Today He Took All The Bushing Out And Oil Them..it's Not Making No Kind Of Noise Anymore
..but I'm Still Worry That Sooner Or Later It Will Be Back...i Had Already Change The Ball Joint Last Week...FOR NOW, ALL MY PROBLEM HAS BEEN FIX..GOOD LUCK TO YOU ON YOURS..IF YOU NEED ANY HELP, JUST LET ME KNOW
Congrats on fixing all your problems! hope you'll never have another one !!
Just a question - did replacing your ball joints change driving feel at all( less steering play.. ETC... - I have some steering play problems.) or eliminate any noise?..
I guess I will try lubricating each suspension components one by one and figure out what's wrong with my car :-)
Thank you - for caring me, thank you for your replies.
Hope I could help you further with suspension noise, to eliminate the "Real" cause !
Also the shop told me the noise is from stablizer bushing...maybe you can try to lubecate it yourself and save some $$..i know how you feel..
can you please tell me where i can get just the bushing for the arms?
Many people prefer to use Mercedesshop.com’s parts shop, but its system is down right now.
So, I searched some on "Partstrain" and...
Here's the bushing:
http://www.partstrain.com/products/E...S-500-005.html
Control Arm Bushing Kit $50.05
Vehicle:
2002 Mercedes Benz S 500
Fit Engine
113.960
Front: Lower
Year 00-06
Suspension page:
And letting you know- the E-bay parts sold off from "Deutsch parts USA" are made by Hamburg- Tecnic. I actually ordered suspension parts from them, and but did not see much difference from the OEM. Although it looked okay, I figured out that these weren’t the OEM parts like what I have desired. After some research on the net, there were many comments about Hamburg-Tecnic that it looks okay – but that its questionable longitivity. There was a web page for introduction of Hamburg-tecnic saying that it's based in India, for remanufacturing & re-stamping of the good that have failed quality controls of various OEM makers. The webpage disappeared, and it’s not on the web anymore. To make things more doubtful, there were some people who praised on the Hamburg- Tecnic products like as if he was the company’s P.R. personnel on many suspension – related thread on a Bmw forum. I am kind of hesitant on having these parts installed, as I do not want to double the cost later.
AAH- things are complicated.
To my knowledge, it is a mandatory to do a wheel alignment after ball joint replacement. If you did not do the wheel alignment, please do so.
If alignment does not solve the problem (I'd say 50% chance that wheel alignment as it does not cause much steering play /wander), your choice would be tightening up the steering gearbox(no parts required :-)!!) ,which could done by mechanic.
I am not too sure about where the volt is located. This volt brings the gears in the steering box closer, hence reducing slack coming from gears sitting far.
Also do not forget about the control arm bushing replacement that I said above, if it has not been done on the car. Worn-out control arm bushing is known to cause squeaks and thumping sounds.
On some cars, this could be caused by the front thruster arm too, which is silver in color if you look inside the wheel house.
Our cars' got just too many suspension components.
Although I am not too sure on what I have problems with for my car, I will try replacing ball joints & control arms at once, then tightening the steering gear. Otherwise, I wonder what could solve the problem. It's just.... really frustrating
I will post the results ASAP when I get the job done on my car.
Thanks!
