Codes from Navi
Sae Code Type CNT State
N1111 0x0190 002 P
B1010 0x0000 001 P
B1762 0x0000 002 P
B1780 0x0000 003 P
Anyone with any ideas what there for? thanks
Cheers, Frank
(would you mind to resize your picture a bit. Its wasted space with every post from you)
B1000 Control Unit A40/3 (COMAND) is faulty
B1002 Internal CAN databus error (RB Can)
B1003 Interior CAN databus error (CAN B)
B1010 The supply voltage of the control unit is too low
B1730 Excess temperature of CD player
B1734 No speed pulses from traction control module
B1736/1 Fault in reading CD-ROM drive – general CD read error, navigation CD unreadable
B1736/2 Fault in reading CD-ROM drive - CD data block read fault.
may not need to replace unit)
B1736/4 Fault in reading CD-ROM drive – read error CD timeout reading data block
B1736/8 Fault in reading CD-ROM drive – Check CD in player
(may not need to replace unit)
B1736/16 Fault in reading CD-ROM drive – Check CD in player
B1738/1 Navigation Fault: GPS report not received
B1738/2 Navigation Fault: GPS aerial short to positive or ground
B1738/4 Navigation Fault: GPS aerial open-circuit
B1761 Cable fault: short circuit of switching line Ant ON
B1762 Fault in CAN communication with A40/3n2 (Navigation processor)
B1765 Component A40/3 (COMAND) is faulty
B1766 Lost Navigation data
B1767/0 Navigation parameter missing – number of teeth of ABS pulse rotor not configured
B1767/1 Navigation parameter missing – wheel size / height ration
B1769/4 Internal traffic data memory: Function software – Fault
B1769/010 Internal traffic data memory: Fault in communication with CTEL or Teleaid
B1779 Fault in CAN communication with TV Tuner
B1780 Fault in CAN communication with Instrument Cluster
B1795 Fault in CAN communication with EIS control module
N1111/x No data transfer between D2B master and D2N component.
The component at location x reports a fault in the D2B ring
N1112 No data transfer between D2B master and D2B predecessor component possible
N1113 No D2B data transfer possible, position can not be located
N1114 Address initialisation of the D2B master faulty
N1115/x A D2B component could not be integrated in the system.
The component at location X reports a fault in the D2B ring
N1116/x Failure of D2B component in position X in D2B ring
N1132 At least one button is sticking for longer that 120 seconds
N1141 Set/Actual configuration of D2B ring differs
N1204/1 Telephone fault with dynamic navigation -No GSM signal detected
N1204/2 Telephone fault with dynamic navigation -No portable recognised
N1204/4 Telephone fault with dynamic navigation -No PIN entered
N1204/8 Telephone fault with dynamic navigation – Directory fault
