S600 Power steering pump question
I have a 1994 S600 coupe, recently, the steering pump started making noise when the wheel is turned, but seems to go away after about 15 minutes of normal driving, the fluid level was low, I topped it off with the correct fluid, but the noise is still there, it sounds like the pump is running with no fluid it it, but has fluid, the rack turns fine, no problems, not tight, the system works fine, but the pump is very loud, any ideas?
1 Post
CLS 63 S AMG , s500,clk550
you have posted in the wrong forum
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
https://mbworld.org/forums/s-cl-class-w140-coupe-67/
