Navi screen will not follow car, stays stationary
2000 S430. Navigation screen will not track while driving so I have to reset the screen to a new location to see where I am and what's coming up down the road. Can anyone tell me whats wrong or needs to be replaced?
A/C seats will not work either. Control will illuminate but cool air will not come out. any idea's what to check?
Drivers side mirror will not defrost, any hints what to look for?
Sunroof will touch closed but open back up....
Looking for suggestions...
Chris
clarson564@aol.com
Chris
clarson564@aol.com
1 Post
CLS 63 S AMG , s500,clk550
i had that same navigation problem i took mine to the dealer and they test drove it and said nothign was wrong with it and it started working with me too.
the a/c seats are really quiet u have to listen in complete silence to hear it. and the drivers side mirror is not suppose to defrost i dont think so atleast i could be wrong.
and when the sunroof goes down it pushes it self back up little bit to even it with the cars roof
Sounds like you might have to do a total system reset on the command system. I had to do that last spring on a long trip from West Palm to Nashville. It happened at about 2AM when I went thru a tunnel under the runway at Atlanta airport. The whole system just locked up and woudn't track. I called MBUSA tech services and they told me that this happens under certain enviroments and requires a reset or re-boot. Once I did the reset I noticed that everything returned to normal but I lost all of the presets that I had stored. Good Luck.
There's no need to reset this. There's nothing wrong with your car. If you read your manual you will understand how it operates. When you are pulling just a map by the location of the vehicle, your screen stays stationary while that little arrow moves (it's just a map to show you where you are). When the arrow gets to the end it stops and you have to update current location. The tracking feature only works while you are following directions to a destination. If you want the tracking feature then I suggest you get a 04-06 with the DVD based nav system. Sorry but thats just how it works.
Oh, another trick is to zoom out as far as your driving range is covered by the map. Mine is typicly 5mi. The further out you zoom the more area is covered.
