No stereo sound in 02 S430
2007 S600, 2002 S430, Bently Continental GT coming soon..., Falcon 50.
My wife had her 2002 S430 detailed last week and they got the amp/CDC/phone wet. A few days later she was driving with the radio on and all of a sudden there was no more sound. Later that day it came back again, then went out again for good. When you select CD it says "NO CDC". I took the CDC/Amp/Phone module in the trunk out and found that the CDC's connectors were corroded. Cleaned and re-installed but still no sound. Seems like the problem is within the CDC. Is there a way to get sound out of the stereo without the CD Changer working? Maybe re-routing the wires?
Any help or feedback would be appreciated.
Thanks!
Thanks!
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Clean the contacts with CRC contact cleaner... and check the fuse on the amplifier. If it still does not work, I would get an estimate from the dealer and have the detail shop pay for the damages.
For now I swapped 2 fiber-optic cables and the sound is back. Un-hooked the CDC and going to order a new one. Since I swapped the fiber-optics I have sound for radio/nav, but the VR is inop. Which she never uses anyways. Learned a lot about the COMAND system and D2B. Sure you all know this, but you can access a hidden diagnostics menu by pressing mute + 1 + 3 all at the same time for about 5 seconds.
Needless to say I won't be using that detail shop again. Hopefully I can get them to pay!!!
When you say you swapped 2 fiber optics to get sound what did you mean by that? I have the same problem. Also which cd changer did you replace it with?
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
![word](https://mbworld.org/forums/images/smilies/werd.gif)
having a similar problem in my 04...so what exactly do you mean?
Im getting "system unavailable" and "no sound" pop ups on my comand
