Slippage?
Old Feb 4, 2007 | 07:04 PM
dtxmob's Avatar
2000 S-Class
Slippage?
Car jerks when I tap on the gas lightly and then apply brake! Feels like the transmission spun a little rumbling I can feel it on the gas pedal!? Anyone know if what it could be. This only happens sometimes when I start off slowly and then have to brake for some reason! Thanks for the help!
Old Feb 4, 2007 | 07:17 PM
newton22's Avatar
BMW E39
Does the tranny kick the car forward from 1st to 2nd?
Old Feb 5, 2007 | 11:10 AM
dtxmob's Avatar
2000 S-Class
I think it's more of like a little rumbling sound or jerking motion as if the car was trying to get into gear??? It revs up slightly and then gets into 1st gear and the car vibrates a little. I used to have a similar problem with my 1990 Acura Legend, but that was because I used to do burnouts from neutral to drive! It is somewhat similar like the car just jerks a little when I give it some gas and let go right away!
Old Feb 5, 2007 | 01:15 PM
zmaster007's Avatar
S320L (W220)
You could try a transmission reset, I cant remember exactly how to do it, quick search will bring it up (could be under throttle body reset)
Old Feb 5, 2007 | 06:50 PM
dtxmob's Avatar
2000 S-Class
Great! Thanks for the info.
Old Feb 5, 2007 | 08:53 PM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
noo thats something else... thats the same thing as resetting the ecu... it makes ur transmission shift faster and harder....
Old Feb 5, 2007 | 09:54 PM
dtxmob's Avatar
2000 S-Class
DOH! Yeah I don't want that! Thanks for the Save! I'll try and have my mechanic take a look @ it!
Old Feb 5, 2007 | 10:05 PM
fusion2007's Avatar
np... i think thats a good idea to have a mechanic look it.. u might need a new gearbox..somebody else on the forum has the exact same problem and it turned out to be the gearbox was really ddirrtyy from all the stuff that was spilled into it...
Old Feb 6, 2007 | 12:40 PM
zmaster007's Avatar
S320L (W220)
My bad, its just that when I did it on my car, it shifted a lot smoother between 1st and 2nd
Old Feb 6, 2007 | 01:10 PM
02S430's Avatar
W220 M113K
mine does the samething but only when driving at around 10mph but if ur accelerating 20+ you dont feel anything, maybe we need some ATF?
