powers steering resevoir
Old Mar 11, 2007 | 08:17 PM
gac's Avatar
gac
2002 S500 black/java/2011 Escalade (wifes)
Does anyone have a picture of the power steering resevoir? I think I might be low and dont want to put power steering fluid where it should not go!
I know this is a dumb question but I appreciate your help.
thanks!
Old Mar 12, 2007 | 10:00 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
thanks!
its the small black reservoir on the drivers side of the engine that is infront of the driver's side cylinder head/valve cover. The cap is about 2" in diameter. Also, this reservoir is bolted to the front of the engine above the p/s pump.
Old Mar 13, 2007 | 11:04 AM
Singularity's Avatar
2005 S500 4matic
Exclamation
thanks!
Warm your engine up to normal operating temperature. Turn your engine off. Let fluid go down off the walls for 2 minutes. Check the level by looking at the cap's inside probe. Check and correct oil level If necessary. Good luck.
Old Mar 13, 2007 | 01:38 PM
newton22's Avatar
BMW E39
The dipstick has levels for both cold engine temp. and warm temps.
Old Mar 13, 2007 | 02:47 PM
2005 S500 4matic
Exclamation
Like It or not but that's what Official Technical Service Bulletin saying - check P/S fluid level with engine at normal operating temperature.
There is a reason for that. Cold check means surrounding conditions of +20 Celcius. And weather is not always +20, now is it?
All the best!
Old Mar 13, 2007 | 10:18 PM
gac's Avatar
gac
THANKS GUYS!
Your help is much appreciated!
