Safe jacking points
Old Mar 19, 2007 | 04:23 PM
RomansDad's Avatar
Lamborghini Countach, BMW M3, ML 500 x2, S500 Lorinser
Safe jacking points
I wanted to jack up the car this morning, but I cant find any obvious jacking spots for a floor jack... All I see is plastic undertray or skirt that looks like it will break if its used to jack the car. Any help (especially pictures) would be appreciated.
Old Mar 19, 2007 | 04:54 PM
newton22's Avatar
BMW E39
For the rear, use the rear differential. I don't know about the front.
Old Mar 19, 2007 | 10:40 PM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
becarefull when you bring the car off the jacks.. from what iv heard on the forum there is a special technique to bring the car down it has to do with teh airmatic suspension its like if u bring it down to much at first it will damage ur suspension.. im not sure what the proper way is but im sure newton probably knows as well as other people
Old Mar 20, 2007 | 06:04 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The "special technique" is only for the S-Class, which has the airmatic suspension - and then it is a factor only if the system is has leaks. It would apply to the Lorinser, but not the other cars.
Also, there are removable plugs on the side of the standard S-Class for insertion of the jack carried in the trunk. They are just ahead of the rear wheel wells and just behind the front wheels wells. They allow the jack to slip into hard points and not damage the trim. I don't know if the Lorinser mod preserved those plugs.
However, one might want to use the trunk jack vice the floor jack if there are questions.
Old Mar 20, 2007 | 03:16 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
My car has rubber bumper under the car for jacking. I dont have the Sport package aero kit tho.
Old Mar 20, 2007 | 05:16 PM
newton22's Avatar
BMW E39
Those rubbers are for jackstands, not jacking points.
Old Mar 20, 2007 | 05:28 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
if they are strong enough for jackstands then they can serve as jacking points as well. I use these rubber bumpers routinely and they work fine.
Old Mar 20, 2007 | 05:35 PM
newton22's Avatar
BMW E39
Understood, but I believe Romans was talking about a hydraulic jack. You jack with a hydraulic jack either the front or back, not a corner of the car. If you would like to jack corners (for changing of one wheel etc.), use the factory jack.
Old Mar 22, 2007 | 02:41 PM
ebolick's Avatar
2000 S430, 1999 E 320, 2 K5 blazers,
I have been using my hydo jack latley to lift my S and i always use the rubber bumpers on the bottom of the car and so far no damage or anything.
Old Mar 22, 2007 | 02:42 PM
ebolick's Avatar
come to think of it use your factory jack and be safe the holes are on the side of the car
Old Mar 22, 2007 | 03:35 PM
RomansDad's Avatar
I have the Lorinser... Factory Jack no longer works.
Old Mar 22, 2007 | 06:55 PM
sprink49's Avatar
2004 S500
Go buy a good light weight aluminum floor jack and use points on the frame right behind the plugs at each location.I don't pull my factory jack out. If I have trouble on the road I'll call roadside assistance.
