Rear power sunshade dead
Old Apr 29, 2007 | 12:13 AM
ProV1's Avatar
MB, BMW
it was working perfect til yesterday but this afternoon it just died. no response when i click the button.. is there a fuse for the power rear sundshade?? any ideas, plz help. thanks
Old Apr 29, 2007 | 10:59 AM
kenstudios's Avatar
Check your fuse chart for the fuse number and location then test the system again.
Old Apr 29, 2007 | 08:19 PM
LUNATICK's Avatar
Mercedes S-Class
Try jerking the two posts on the side with your hands, sometimes they get jammed.
Old Apr 29, 2007 | 08:21 PM
Chucky300's Avatar
2014 S550
thats what i did on my old s500 and it worked everytime
Old Apr 30, 2007 | 01:23 PM
ProV1's Avatar
MB, BMW
mine is retracted in and won't come up. i will try pulling it up manually to see if it's stuck. i doubt it though
Old Apr 30, 2007 | 07:40 PM
notoriousALE's Avatar
02 S500 02 X5
Check fuses. Yank on it. If nothing happens leave it alone. If you want to fix it get a new motor for the shade. I have removed one before and it was a PITA. Rear seats come out, parcel shelf comes out, trunk panels and rear head rests come out, THEN take out the shade unit. Most likely the motor is weakened, and dying. Seriously leave it alone unless you wanna pay................
Old Apr 29, 2015 | 09:34 PM
Samo818's Avatar
2004 mercedes benz s430
Same problem on my w220! I press the button i hear a click but nothing happens, fuses look okay i just want it to be down helpp?
Old Apr 30, 2015 | 10:12 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Samo818, in the case that your's is up, try wiggling both sides of the window shade bar while the car is running. You can also try the same approach with someone pushing the shade button while you are wiggling it around.
Old Apr 30, 2015 | 12:39 PM
Samo818's Avatar
Talking
I did it!!! So the shaking and stuff didnt work i opened the trunk and located the motor and theres a small thing sticking out from the motor while i had someone push the button, i pressed that thing nd it started to roll, my conclusion is that that little thing gets stuck and someone has to press it to work
Old Apr 30, 2015 | 03:51 PM
ibeforreal's Avatar
Glad it worked out for you.
Old Jul 14, 2017 | 08:32 PM
Tom Libonati's Avatar
2015 SLK 350, 1999 SLK 230 Kompressor
Sunshade stuck in up position...
I’m 17 and just bought a w220 S430, it’s a 2002. It has the side window roller blinds and the rear window sunshade.
just like Samo818 my car is doing the same thing. I don’t know how he made it work. I looked in the trunk, found the motor but couldn’t get anything to happen. It’s stuck in the up position and I can’t stand driving like that.
Old May 24, 2021 | 11:51 AM
sprink49's Avatar
2004 S500
I know this is an old thread, but this worked for me: Get someone ready to push the shade button on the dash with the car running. Get in the back seat and grab both side arms. Tell your helper to push the button...immediately pull the outside arms towards the center of the rear glass from the side. This will free up the arms and allow it to go all the way down.
This worked for me. I am going to leave it alone, keep it closed and not tempt fate !!
