How to replace door mirror indicator lamp
A few of the LED's are burnt out on the pass mirror indicator strip.
Can I pop out that piece with small screw-driver? Before cracking the assembly, thought I'd ask.
TIA
TIA
S500 W220
Do like my wife did. Back the car out of the garage and let the mirror hit the side of the wall.
There are other posts on this issue.
https://mbworld.org/forums/showthrea...ferrerid=51794
If you look between the mirror and the door window you should see a metal tab. This tab holds the mirror towards the door. Use a screw driver to asset in popping the mirror assembly outwards. Slide the cover off, there are tabs that hold it to the mirror frame. Again there are wires attached.
Todd
Todd
