Comand 2.5 2001 S430 D2B Wakeup Test Error
If its the COMAND unit,. MB will say buy a new one (big dosh) - you could try ebay - the COMAND2.5 units are not that expensive as they can only fit in S/CL of certain model years
If its the cable, it should be easy for an auto-electrician to fix.
R
Better yet, I would take it to your dealer or trusted independent shop. The COMAND systems are very complicated to work on, and you might make it worse off than it is already.
1. green wire with a white stripe
2. radio mute wire
3. 2 x black paired wires
4. There is no C1 connector at the moment (TV connector I think)
Any thoughts on the above wires?
Any thoughts on why the navigation section has no power? I am a little concerned it is a faulty unit as I would expect to be able to press the eject button and here cd motor drive noise, or be able to insert a disc.
I too went into the wake up diagnosis mode to check, however, I wonder if:
- the unit is faulty hence no power on
- the car needs to be programmed to say it has navigation so the can bus powers up the navigation part of the comand
- the green wire above needs to be connected to get the unit to power up
Any help would be appreciated as I would really like the navigation unit working.
Thanks in advance.
