Power Steering
Old Jul 10, 2007 | 01:50 PM
jmiaebrown's Avatar
2000 S430
Power Steering
I am experiencing a whining noise when I turn the wheel. I believe my power steering fluid may be low. I am not quite sure if I am looking at the correct area. Does the cap have a small dipstick? What I am looking at does. I don't see any fluid on it. What brand of power steering fluid should I use? Does it have to be Mercedes brand?
Thanks for you time.
Old Jul 11, 2007 | 12:35 AM
02S430's Avatar
W220 M113K
yea thats the right one, mercedes has one they perfer
Old Jul 11, 2007 | 01:42 AM
whoover's Avatar
'19 E63S sedan
You should take it to the dealer. If it's low, you have a leak.
Old Jul 11, 2007 | 11:32 AM
LetsJet's Avatar
355 F1 Spider & ......V12 w220.176
Correct......
Old Jul 12, 2007 | 09:06 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
There may be another reason also for that noise, if it does not go away by adding P/S fluid. It is a sound like "dry" plastic on plastic and comes from a bearing between the steering column and the top of the P/S gear. If this is it and you are out of warranty my guess $ 400 to fix it.
Old Jul 18, 2007 | 01:24 AM
Big "H"'s Avatar
Get it fix ASAP, this could cost you $$$ in the long run.
Big "H"
Old Jul 18, 2007 | 12:19 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
My dealer topped off the PS fluid and the sound was gone. The tech inspected the system and found no leak. No sound for over a year now. Nothing on the garage floor either.
Old Jul 19, 2007 | 11:09 AM
sessayan's Avatar
2002 S430
My car did the same thing. Had a noise and was low. Dealer checked and did not find a leak. They topped off the fluid and the problem went away. I think these cars must eat the fluid.
