Auto locked
5 weeks later after many lost emails the new key arrived. The car battery was re-charged and the key inserted and re-programmed, a three hour process I was told.
The Engine was then started ok, but apparently the gear leaver wont move?
From the dealers email im not sure weather the gear lever is jammed or locked.
May be the key didn't program properly?
Another friend mentioned that if the battery goes flt the ECU needs to be reset?
Any opinions would be appreciated.
Car has travelled 71,000km
Regards Simon
...problem probably lies with the selector control unit."
Next reply.
Additional parts that maybe required may also be available for further discount to us, to assist us in correcting all faults. "
The central locking stopped working so I asked if this could be effecting the anti theft system.
The reply was
" Have followed this through with our Service Dept, they have shown me that the central locking has no relative connection to the gear shift mechanism, we got the remote central locking to work using one key, the other key only worked very inttermitently.
With the central locking unlocked with the key, the shift lever still does not want to move.
Any help would be appreciated.
There thats a thread from another forum that explains what I think may be happening to your car sadly it's not a cheap fix....but you never know it might be something to do with the keys.
It could be that the brake light switch is u/s, to test it, turn on the ign and press the brake, if you have your hand on the gear lever when you do this and do not feel a click then the switch is faulty.
However if you feel a heavy click then the switch is ok, the electronics in the Selector unit are ok but has a mechanical failure in it. This means the whole unit has to be replaced as it has some armour/ high tensile steel plating in it.
I know a guy who replaces the units within an hour in the UK.
Best Luck
