Tank Content/After Start/After Reset Screen HELP!
The "After Reset" screen shows the cumulative miles driven after you MANUALLY reset this feature, as well as the average MPG since reset. If you do not manually reset this screen at fill-up, it will show all the miles travelled since it was last reset manually.
The "miles to empty" screen uses the average MPG (after reset) AND the current MPG (after start) to give a fairly accurate estimate of how far you can drive until you run out of gas. If you leave this screen on, you can see the estimate change up of down depending upon your current MPG.
This is what I do at fill-up. I scroll to the Odometer screen, which shows the total vehicle mileage, as well as the trip mileage. I press the "R" button to reset the Trip. I then scroll to the "After Reset" screen and zero out the mileage and average MPG. I then scroll to the "After Start" screen and reset that because it usually won't reset after a short off period just to refill the tank (like I said above, not sure how long the engine has to be off for this screen to automatically reset)
Hope this helps.
