How To Install OEM-Bixenon Headlights On 2002 W220.
White S63 AMG W/Designo Interior
i installed the headlights, they plugged right in, all i had to do was ground the self leveling plug, all the parts of the headlights work, except for self leveling , i couldnt figure it out, but its lighting up the road good without self level
1 Post
W220 M113K
wat about a local car shop?
here in BK
we have one for benz, i seen like SLRS and S65 there always.
they go there for repairs instead of the stealership rofl![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
here ask this guy he was selling Bi-Xenons b4
http://youtube.com/user/cgreen365
here in BK
if you dont ground it with the special adapter you will get l turn signal and right turn signal error on you dash...so whoever is doing this mod get the adapter it takes 5 mins to put in.
02 S500 Sport
#32
here in BK
here in BK
#33
You will need an adapter to install the OEM Bosch xenon version (2003 - later) into the 2000-2002 car. The plug are different. I saw some place sell these adapter for $10-15/each.
The plugs for the auto-level are the same, but the one for the headlight is a bit different.
Since your car already have xenon, you do not need to reprogram the car to recognize xenon, so that's the good news.
Once you have an adapter, it shouldl all work out, the internal of the Bosch version already wire to handle the bi-xenon feature. Notice that the Bosch bi-xenon projector run three wires (negative, hi-positive to trigger open, low-positive to maintain open), so don't try to wire them manually, you'll fry the bi-xenon solenoid in no time . The instruction from Ray work with most bi-xenon projector, except the Bosch E46 projector (used in this headlight)
Loosen up the front bumper a bit will make it much easier to install the light. If you need instruction, I'll put the WIS and post instruction here.
Seems like autowerksdirect.com is down
Any information is greatly appreciated
You mentioned that it's not good to ground the wires for the bixenon highbeam???
#34
2000 W220 s430 (they just gave it to me!)
We are still here CANBUS WIRING HELL
Hello MB World!!
I too am in Wiring hell. My case is I have a Halogen 2000 W220 and I have the Autolevling only harness. I'm at the point where there are 3 wires and I'm not sure on where to stick them.
I'll post as I find more info but. If you know.. ya know.. let me know..
OK later
OK later
