need help with 03+ headlights and auto level on a 01...
Flying Spur
ever since i got the lights put in by the body shop it seems that they've always been shooting up in the air...so i lowered them to the lowest setting and everything was fine...well until i started the car agian...they went down then back up into the air (im pretty sure it was the auto levelling that did it...so im wondering now if i can get that feature disables via star diagnostics from the dealer...or...is there a fuse or something else that i can disconnect in order to get rid of the problem...any help appreciated and thanks in advance...
White S63 AMG W/Designo Interior
the second plug has 3 pins discoonect two of the pins only leave the ground it will disable the auto level........im not using auto level and everything works perfect
S, GL, Escalade ESV, my shoes
Flying Spur
thanks guys...i disconnected one wire on the passenger side and not the driver side but it seems to have fixed the problem...everything else functions fine so i guess im in the clear...the plug i pulled had four pins in it...thanks guys...
