Bluetooth Question
Old Oct 31, 2007 | 01:18 PM
kiddhan625's Avatar
2002 S-430
Bluetooth Question
I got a letter from AT&T that starting Fed 2008 they will not support my CDMA Startec Phone that came with my 2002 S-Class. SO my question is....do any manufactures make after market bluetooth kits for our cars and if so where could I get one? Any help or input would be appreciated. Thanks
Old Oct 31, 2007 | 03:06 PM
icwater's Avatar
2000 S430
yea look at the sticky in the stereo etc.. forum
Old Oct 31, 2007 | 03:07 PM
icwater's Avatar
2000 S430
https://mbworld.org/forums/showthread.php?t=188818
Old Oct 31, 2007 | 06:28 PM
kiddhan625's Avatar
2002 S-430
Thanks Guys. Seems like V60 Bluetooth module may work.
Old Oct 31, 2007 | 11:24 PM
OBXTucker's Avatar
'04 S600
the v60 bluetooth puck works perfectly. just drop it in the cradle and sync with pretty much any bluetooth phone.
Old Nov 1, 2007 | 12:04 AM
icwater's Avatar
2000 S430
well he needs the puch a v60 cradle and the PSE with an Autosense, so it's not quite that simple or i'd already have it in my car
Old Nov 1, 2007 | 06:01 AM
kiddhan625's Avatar
2002 S-430
If I already have a car phone system do I still need the cradle and PSE with Autosense? I would assume the my pre-existing cradle would work.
Old Nov 1, 2007 | 11:07 AM
OBXTucker's Avatar
'04 S600
If he has an '02 phone installed with the cradle, isn't it already Autosense/PSE ready?
Old Nov 1, 2007 | 11:14 AM
icwater's Avatar
2000 S430
the puck fits in the v60 cradle it will not fit in the startac cradle i have the same setup as you and yes you need the PSE with Autosense
Old Nov 1, 2007 | 11:28 AM
icwater's Avatar
2000 S430
i dont think the cars with the startac cradle are, though i'm not positive. i pretty sure if you read though the whole thread i linked it will answer these questions
Old Nov 2, 2007 | 07:18 AM
kiddhan625's Avatar
2002 S-430
So I looked into this further and found the following:
1. I have the Timeport Phone which means I will need to purchase the v60 craddle. (V60 cradle short-cord kit Q 682 0724)
2. I do have the PSE with Autosense based on the following information off of:
http://home.earthlink.net/~phdwebsit..._bulletins.htm
2002 Model: PSE “Auto Sense” (SYN 9266A) BQ 682 0754
2003 Model: PSE “Auto Sense” (SYN 9266B) Q 682 0845
Old Nov 2, 2007 | 07:38 AM
qriousrich's Avatar
S500 Designo/Mocha Black
Can someone confirm this? From wireless4mb.com there are only about 3 phones available from Verizon, At&T and 2 from Tmobile. Don't know if it differs for the year 2000. I wanted to sync it with my Iphone but don't know if it's possible.
RICH
Old Nov 2, 2007 | 05:50 PM
icwater's Avatar
2000 S430
RICH
somewhere in the thread i linked theres a link to a site that has all the phones that have been tested and worked with the puck, i seem to remember the iphone works but i thought there was a problem with the phone book or some ****
Old Nov 15, 2007 | 12:40 PM
tuckda's Avatar
2002 S430
Unhappy Still Have a problem
I have a 2002 S430. I converted the phone cradle to a V60 and inserted the V60 bluetooth and nothing happened. ie no light came on the puck so I could start the paring process. I have not verified that my PSE is Auto Sense (Syn 9266A) BQ682 0754. Do you think the PSE is the problem?
Thanks,
Dan Tuck
Old Nov 19, 2007 | 06:31 AM
qriousrich's Avatar
Thanks,
Dan Tuck
When I converted my startac to v60 I had to change the PSE also. I'm almost positive that its not compatible with the v60. You can try to talk to the guy on the parts department to see if you can try it out and return it if it doesn't work. All electronics are not returnable, exceptions ofcourse. This is what I did but I didn't have to return it. What kind of phone are you syncing?
RICH
Old Nov 19, 2007 | 05:53 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Thanks,
Dan Tuck
Dan, you definitely need an Autosense or straight V60 PSE. However, your car should have been equipped with an Autosense unit. Still, if it was manufactured near the changeover of equipment, it may not have one. Best to check.
You might also check fuses and connections, both power and copper wire, to the PSE. Also, everything that should be in your fiber optic loop should be connected (see the phone bulletin for your car; http://home.earthlink.net/~phdwebsit..._bulletins.htm).
Old Nov 30, 2007 | 07:04 AM
silver65's Avatar
2003 S600
I have a 03. I purchased the puck, plugged it in and Viola, worked perfectly with my Samsung I730. I would imagine just about any bluetooth phone would work.
Old Nov 30, 2007 | 07:39 AM
trumpet1's Avatar
2007 S600
Have you looked at www.wireless4mb.com ?
Old Dec 1, 2007 | 10:40 PM
Big "H"'s Avatar
What is the average cost for a Auto Sense PSE, and best location to purchase one?
Big "H"
01 S430
