MB Coupons
Old Nov 1, 2007 | 03:17 PM
estrain_ny's Avatar
2001 S500 and 2000 BMW 740I
MB Coupons
Hi all,
I just came across some coupons at my local stealership and wanted to know if all MB dearlership has them. See attached.
http://www.silverstarmercedes.com/ou...rvice_specials
Old Nov 1, 2007 | 05:00 PM
icwater's Avatar
2000 S430
http://www.billussery.com/mbcenter/b...specials.jhtml
well theres a specials section with no prices weeeee :p jackasses
Old Nov 1, 2007 | 05:41 PM
Chucky300's Avatar
2014 S550
Service A Coupon
What we do: - Change your vehicle's engine oil and filter - Replace the dust filter in all SLK, CLK, C-Class and E-Class models - Ensure the warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, and seat belts are functioning correctly - Inspect tires and check tire pressure (including spare) - Inspect brake pad thickness and disc condition - Check and correct all fluid levels - Reset your vehicle's FSS counter *Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Service B Coupon
What we do: - Change your vehicle's engine oil and filter - Replace the dust filter in all SLK, CLK, C-Class and E-Class models, and in S-Class and SL-Class models without the active charcoal filter - Replace windshield wiper inserts - Inspect and rotate tires - Lubricate and inspect throttle linkage - Ensure the parking brake, steering play, headlamps and exterior lamps, warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, seat belts, and backrest lock (S-Class only) are functioning correctly - Inspect tires and check tire pressure (including spare) - Inspect brake pad thickness and disc condition - Inspect front axle ball joints and Poly-V-belt - Check and correct all fluid levels - Reset your vehicle's FSS counter *Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
The checking of all the other things like the Axle Ball Joints etc are what makes Service B so important?
Isn it just "checking" for 5 or 6 minutes to see its still there and in good condition?
