Is it worth fixing the side mirror light?
https://mbworld.org/forums/s-class-w220/115757-2000-2002-s500-side-mirror-led-light-upgrade-before-after-picts.html
Beside just giving opinion, no one on this forum will fix your car for you, you have to handle that on your own..
Don't forget to chime back in, I'm interested in knowing how it all works out for you.
Whatever costs $400 to fix might be worth it IMO. An entire mirror assy. is much more than that. If you end up with nothing more than a new housing and light assy, that costs about $225 in parts and takes less than two minutes to swap out, then all we can say is that we told you so....
Good luck...
Audi did that on the driveshaft connecting to the rear drive in a Quattro system. The shaft, called a propeller shaft, has the exact same inner CV joints at each end that were used on the axles. They were removable, and each CV joint cost under $200. Propeller shaft faillure was not common, but when it happened it could immobilize the car. Audi would not allow dealers to replace a CV joint on a propeller shaft, and required the owner to bear the entire $1100 cost of the part - usually waiting about a month to get it, while the car could not be driven.
When I replaced the second one on a car (where another dealer had failed to detect a bad motor mount that was causing premature wear), the service manager brought out the remaining good CV joint, handed it to me, and said if the shaft ever failed again take it to an indy and have him just replace the joint.
Your mirror problem could be similar - I don't know. But I do know that you can follow the advice you have been given repeatedly above. If you search enough, there are even DIY instructions on the forum - perhaps even in the link you were given by 2H S5.
You will find plenty of occasions where forum members advise folks to consult the dealer, or to follow a dealer's advice. Sometimes that's just the best answer. You will also find plenty of MB techs - independents as well as dealer techs - answering here. Some of these folks may give you a better way than your dealer has.
And you'll find folks here who have repeatedly done things successfully that a dealer told them couldn't be done. In those instances, it turns out, we knew more than the dealer - at least, more than the person we spoke to at the dealership. It's not uncommon.
More importantly, perhaps, you'll find owners trying to do things that both the dealer and the forum members agree cannot or should not be done. It's probably best to heed that advice.
Anyway, I agree with prior posters. If you want to rely on your dealer in all circumstances, go ahead. But if that's your choice, why waste our time with questions? Just ask him.
YOu have a total moron for a Service Rep. Stop talking to him and go to the parts counter and order a F&*(&ing light already. I just priced one for my car AT THE DEALER and it was $59.00. My housing was cracked so I got them both for $225.
IF you dont want to go the extra step of going to the parts counter, then keep listening to the idiot who obviously does nothing all day but take in broke cars adn feed customers B.S
LOL
