Acceleration Problem
Rating: Thread Rating: 3 votes, 5.00 average.
Old May 10, 2012 | 07:36 PM
  #51
Steve J's Avatar
1989 560SL
Talking 2001 S500 Acceleration Hesitation
Gentlemen thanks so much for the Heads UP..
I have just started to have the exact problem
The Forum tells all.......thanks ........Steve
Old May 27, 2012 | 03:06 AM
  #52
jitterbugvan's Avatar
2001 mercedes s430
had same problem..ordered pedal on ebay 130 bux...got it ..installed in 5 min..and rides smooth as ever..this forum saved me some cash..thanks guys
Old Jan 12, 2013 | 08:19 PM
  #53
aselvan's Avatar
2008 c300
Same problem on my 2002 C320. Replaced the Throttle Pedal Assembly ($156 at ecstuning.com) and the problem is fixed. Thanks to this forum post!
Old Nov 9, 2013 | 03:45 PM
  #54
Themightyangelo's Avatar
2000 mercedes s430,98 slk230, 78 300d,93 300e, 95 bmw 318ic
Same problem I'm stumped
Hey all, if anyone ha some advice I'd appreciate it. Same issues from cold start poor low idling once warmed and screw with revving it up in mornings to be able to back up drive way it's still having issues after warmed up if I give her too much gas sometimes and goes outta gear. I have replaced pedal 3 x all from junk yards tho, put new 02 sensors on it and coil packs. It is still showing up as tps in foot pedal, I m not sure it will help but am going to put new throttle body and mass airflow bc have found both for $80 or should I just get new pedal I mean hell all four can't have been bad?
Old Nov 9, 2013 | 03:48 PM
  #55
Forgot
Forgot this was my 2000 s430. I love this car but it has been a nightmare lol
Old Nov 9, 2013 | 05:42 PM
  #56
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
id get new pedal since that's what you've changed 3 times already with used ones, then clean the maf and throttle body with cleaner, clean those first and see if you have any change. but most probably its the peddle.
Old Nov 10, 2013 | 09:56 AM
  #57
wallyp's Avatar
2003 S500 2007 GL450
The odds of getting four faulty pedals in a row are pretty high. I would start checking for a broken wire or faulty connection in that circuit.
Old Nov 10, 2013 | 05:03 PM
  #58
Yea
That's what I was thinking Wally I checked all wires and connections and all seemed great so was thinking throttle body it's used but only $50 from car parts
Old Dec 13, 2013 | 05:50 AM
  #59
ayman0579's Avatar
W220 S500 2003 // w126 SEL560 1990
I faced this problem with my S500 2003 and I fix that. After I changed the paddle with air mass, the check engine come again with the same problem after 2 month. That was when the ESP was off and on slip road drifting the error came on screen ESP malfunction and the paddle not responding at all. After I restart the car, the check engine light come again with no malfunction and the problem came again. Any idea or solution of this nightmare.
Old Dec 13, 2013 | 06:55 PM
  #60
corkshoppe's Avatar
Top Answer: 1
wheel speed sensor is bad and throwing the eps code. but check the connections for the strut behind the front wheels, might be loose.
Old May 19, 2014 | 12:23 AM
  #61
LTECK's Avatar
01 CLK320
ESP LIGHT TURNS ON, THEN NO PEDAL RESPONSE
HI EVERYONE! MY FIRST TIME TO POST SO PLEASE BEAR WITH ME. I HAVE AN '01 CLK320 AND INTERMITTENTLY HAVING AN ACCELERATION PROBLEM. WHILE DRIVING ON THE ROAD, THE ESP LIGHT WOULD TURN ON I WILL LOOSE ACCELERATION. MEANING THE GAS PEDAL DOESN'T RESPOND AT ALL. THEN WHEN I TURNED THE ENGINE OFF AND RE-START THE CAR IT WILL BE FINE AND THE ESP LIGHT IS OFF TOO. THIS HAS BEEN HAPPENING MORE OFTEN EVERY DAY. SO PLEASE I WOULD GREATLY APPRECIATE ANY IDEA ON WOULD BE CAUSING THIS PROBLEM! THANK YOU!
Old May 19, 2014 | 12:10 PM
  #62
mcguirja's Avatar
Mercedes SL63 AMG; Mercedes E63 AMG S 4matic; Mercedes C43 AMG; Mercedes S Class, Mercedes GLK
I had this problem with my S430
Turned out it was the CPS (crankshaft position sensor). Not sure if the CLK is the same or not though. If you have an OBDII reader, you can read the code. I would also suggest re posting a new thread to the CLK forum, which is here:
https://mbworld.org/forums/clk-class-w208-5/
James
Old Jul 30, 2014 | 12:13 PM
  #63
Jam clk55's Avatar
clk55amg
I wish I had found this place sooner I'm having the same problem
Hello all,
very new to posting here I've been reading a while. I have a CL K 55 AMG 02. I have the same lack of acceleration problem as discussed here. I've had the vehicle at the American service center in Arlington Virginia three times and they have changed the throttle position sensor supposedly twice. And supposedly cleaned the throttle body housing. Even though they can't get it to duplicate the problem. After driving the car three days I have experienced the same loss of acceleration has described here I can shut the carl off and started it back up and it's fine for a few hours to a few days perhaps but then it happens again. I would like to try the accelerator pedal fix but I'm having trouble locating a place that has the 02 CL K 55 AMG accelerator pedal. would appreciate being pointed in the right direction to fix this vehicle. also is there anything other than the accelerator pedal assembly that needs to be purchased to complete this fix or does everything come in the same box.
thank you
Old Jul 30, 2014 | 05:29 PM
  #64
tusabes's Avatar
Mercedes
Call autohausaz.com or any Mercedes dealer and buy a new pedal
Old Jul 31, 2014 | 02:19 PM
  #65
Jam clk55's Avatar
clk55amg
thank you.
Old Jul 31, 2014 | 05:40 PM
  #66
AutohausAZ-Mike's Avatar
Former Vendor of MBWorld
Thank you for mentioning us Tusabes!
At the moment we only carry the accelerator pedal sensor. If you would like I could see if we can source the assembly for you.
Here is the link for it:
(Accelerator Pedal Sensor)
AutohausAZ - Accelerator pedal sensor
Disclaimer: Make sure to verify the year and model of the vehicle to insure fitment.
Old Feb 27, 2015 | 07:34 AM
  #67
Julio77270's Avatar
Slk 32 Amg
Will it be possible to have the same problem only at high rev ? (after 5000rpm), lack of power. My IAT is good, MAP also and no leak , no fuel issue and CPS already changed.
My throttle body has been already changed without any effect but not the pedal assembly...
I have no code on my Dashboard I can only see the air mass volume decreasing after this rev. So, I could be a pedal assembly sensor issue...
Regards,
Julio
Old Dec 3, 2015 | 05:47 PM
  #68
antnyc's Avatar
2004 S430, 2011 GL450
Accelerator Issue
Everyone,
I purchased the replacement part, but it is not intuitive as to how I'm supposed to remove the bad part. Can someone share a document or video?
Thanks for your help!
Old Oct 3, 2020 | 03:30 PM
  #69
Chad Williamson's Avatar
2001 S500 (W220)
S500 Loses power
I have a 2001 S500 that only seems to lose power at freeway speeds while performing right hand turns only? I get the yellow caution light flashing then when I straighten the vehicle out it all goes away. If I'm in cruise control and make a slight right turn cruise control automatically turns off yellow caution light flashes and continues to be intermittent power until I straighten out again, again this is only on right and turns.
Any help would be extremely appreciative
Old Dec 12, 2020 | 11:29 PM
  #70
vixapphire's Avatar
2001 S500 Sport "Klaus"
I have had the pedal sensor problem twice now in a 2001 S500 I've owned for as many weeks. It became an issue for me both times after I used a USB adapter in the cig lighter to charge an IPhone. First time, replaced the pedal ***'y. Now it happened again. Nothing else points to this fault than the use of the lighter socket in this way (did it today for the first time since before replacing the pedal last week).
I may just be superstitious here but going forward (after the second replacement of the pedal) I won't be using the lighter socket anymore to charge the phone!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
