Transmission Issue Maybe?
My wife thinks I am over sensitive and she does not feel anything when she drives the car or is a passanger.
I just think that you shouldn't feel these cars shift when they change gears.
Any input would be great as far as how their car feels when it shifts as well as any common tranny issues.
Car is still under CPO until end of Jan 08 and 100K miles. Want to make sure all is right before warranty runs out.
Thanks.
You may have to have your shift controller replaced; the adaptive transmission function zeroed out and reset; or a re-flash of your firmware.
After registering the problem, if you feel ambitious, you could try resetting the adaptive shift (learning) feature. See http://www.benzworld.org/forums/w220...smission+reset, http://www.benzworld.org/forums/w208...procedure.html, and if you use the ECU reset procedure, see http://www.benzworld.org/forums/w220...ml#post2216730. If you have an Audio 10, 30, 50, or other radio besides COMAND, be sure you have your radio code before disconnecting the battery (I know; you have COMAND - it has no radio code - but owners of other models occasionally read this forum as well).
Do you feel your car change gears? ( its not alot but you do feel it)
As far as I can remember the gear shift was un-noticable prior to the dealer finding the leak at where the wires enter the tranmission and replaced a gromut adn added tranny fluid.
Am I being over picky? Maybe you do feel a slight change when the gears shift. Any thoughts?
Thanks.
