Alternator problem
Old Dec 28, 2007 | 04:44 PM
kor's Avatar
kor
MB S320CDI 2001, VW Golf Variant 2001, BMW E36 328I cabrio 1998
Alternator problem
Hello all,
I had a problem with my w220 (diesel). Alternator seemed not to be charging the battery. (voltage to low<11 V)
Today I have charged the battery.
Started the car and the voltage over the battery poles was around 14 V with running engine.
Now I suspect I have an alternator problem. Loose contacts, worn brushes or something like that.
Does anyone now of a way to check/replace the brushes without taking the alternator out first?
Or are there suspect point for intermittent contacts?
Reason for this question is that taking out the alternator is a terrible job because it is a watercooled one and I would have to disconect loads of tubes and let away the cooling fluid..
Old Dec 30, 2007 | 11:19 AM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
I would also check the voltage regulator before taking the alt. out.
Old Dec 30, 2007 | 11:31 AM
kor's Avatar
kor
Hello srknutson.
will try to do that.
(after finding out how to take it away without taking out the alternator)
