Reset Tire Pressure System? S55
Press the "R" on cluster, it will ask if you want to reset current, press "R" again and you are done. You will have to drive a couple of miles for the tires to warm up before you can get a reading.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If after driving a while you don't get any readings and the message reappears, you have a bad TPMS sensor.
This is normally the case when your reactivate message appears on the 2003-2006 W220's. Do you have factory wheels still?
1992 400E, 2003 S55, Porsche 911S
Yep, factory wheels. Also replaced one wheel sensor since PO used wrong valve stem cap and eroded the stem. All wheel sensors test OK with remote tester. Reset on dash menuing system never shows pressures or any other message other than "reactivate tire pressure management system."
