Seat Trim Replace DIY- Fuzion, Skylaw?
This morning I realized there is a big hole in the plastic of my seat also.
The good news is that I ride with my seat so far back that the missing piece is blocked by the door pillar. The bad news is I will still have to replace it and the one on the floor where the seat slides forward and back. I will probably opt for the wood pieces above for the seats and will have to get the other part form MB.
NO joke took me no more than 20 minutes to do:
tools I used:
-breaker bar (probably a good sized ratchet would work, not the oompa loompa small ones) for the seat belt anchor bolt, this thing can be on there pretty tight it seems like
-I dont even know what to call this but a star thing pretty sure size t-45
-phillips screw driver, average sized one
-and of course the new trim piece lol
1. I took the cover off the seat belt anchor bolt (found $2.37 in change here so take that off the total cost
) This just popped right off, i had a flat head handy just in case but it came right off.2. removed bolt using a breaker bar, and a star thing, I think it said t-45 on it(dont know how I had this or why but I did in my tool box this and a tiny one haha fit like a glove, its a pretty large one so you will need this)
3. removed the small phillips screw located in the rear of the trim theres a tiny hole just stick a phillips screw driver in there its gotta be kinda long and an average sized one.
4. remove trim piece (since mine was already pretty beat up I just pulled and it came right off)
5. I took this time and cleaned all the hard to reach areas around the trim.
6. worked the trim back on (basically I just alligned the hole for the anchor bolt, and then just kinda worked the piece all around)
7. put seat belt anchor bolt back on, then tightened the screw located in the rear (the new trim already came with one in it so I just had to screw it in
PREEETTY PREttty easy stuff
tools I used:
Couldn't believe how flimsy and cheap they were and I'm only 145 lb.
I forgot how much they were for the replacements but they were pretty outrageous (over $100???). If they broke before, what's the point of replacing the same cheap pos again?
I bought a wood cover from this seller (not me nor do I know this person).
I was surprised the wood matched too and much cheaper than oem
It came with 2 piece, don't be surprised that it looks like it won't fit, but it did!
http://cgi.ebay.com/ebaymotors/Merce...em320207294271
For those who have removed it, is there a better way to secure it, or some way to put foam on it to quiet this stuff down.
I also like the cover up piece that looks like wood.
Good Luck All!
A class action will get you 45 cents on your $45 part, and take 5 years to do it. It could possibly make the attorney handling it a fair sum - but that's about it.
I'm thinking of trying to fix it myself, is there any danger in badly adjusting the seat belt? That's the only thing I worry about..
So far, I got a ratchet with a T-45 sized bit. It worked perfectly, and the bolt actually was not hard at all to take out, barely took any force.
That's as far as I've gotten, as I don't have the new plastic pieces yet, so I did not take it apart further.
Question: The first aid box has a screw that seems to connect to the part that cracks, #10 in the diagram, where the pulse/dynamic seat thing is located. How do you access that screw? The first aid box seems to block any entrance to it, so do I need to take out the first aid box?
https://mbworld.org/forums/s-class-w...placement.html
He seems to be able to match any colour, although I was sent Walnut when I specified Chestnut. This is now on it's way.
The item is not showing anymore for some reason, but he orders it from a company who make them to order.
If interested, drop me a private message and I shall give you his ebay Id.
Admin - Is this ok to do?
Kevin
and I think mine creaks a little too.
